EG7FDA. AWARD Almería Feria of August HAM RADIO Association URE of Almería ( Local URE's Section ) organizes the 3 AWARD Almería FEST of August, in accordance with the following bases:
1.- all-comers: Will be able to choose all the radio hams with license in force and listeners ( SWL ), radio stations club and associations with own index than be in possession of the correspondent item official license.
2.- call: “You give EG7URI as a gift of August.”
3.- Bands: Every band every mode, obeying the IARU's recommendations of Band's Plan.
4.- Dates: From 18 to August 28, 2017
5.- Rewards In order to choose to the AWARD:
Category Basic 3 Contacts in 3 days no matter Banda or Modes
Category Silver 6 Contacts in MINIMUM 3 Bands no matter Modes
Category GOLD 6 Contacts in all the Modes and a MINIMUM 3 Bands
Between all the all-comers that they keep bases, them all will be given away to with an allusive diploma Almería's fair, free and in format “ pdf for his ONLINE. is the Web habilitated for it ...
6.- granting stations: The OP. will be the Local Section of URE ALMERIA,, bestowing a contact for band upon a same station day..
8.- the interchange of cards is not necessary, If somebody needs any Special QSL similar EG7FDA to the award, pannier only direct road, and they will have to relax in intensity on car pointed with franking enough for return.
9.- the participation in this Award entails the approval of present them bases, the Organizing Committee's decisions are without appeal.
QSL via EA7URI.
SECCION LOCAL URE ALMERIA, P.O.Box: 389, Almeria 04080, Spain.
3º DIPLOMA Almería Feria de Agosto 2017 La Asociación Unión de Radioaficionados Españoles de Almería (Sección Local de URE) organiza el 3º Diploma “Almería Feria de Agosto”, con arreglo a las siguientes bases:
1.- Participantes: Podrán optar todos los radioaficionados con licencia en vigor y radioescuchas (SWL), estaciones de radio club y asociaciones con indicativo propio que estén en posesión de la correspondiente licencia oficial.
2.- Llamada: “EG7FDA Feria de Agosto 2017.”
3.- Bandas: Toda banda todo modo, respetando las recomendaciones del Plan de Bandas de la IARU.
4.- Fechas: Del 18 al 28 de Agosto de 2017
5.- Premios y diploma: Para optar al Diploma :
Categoría Basic 3 Contactos en Diferentes días sin importar Banda o Modo.
Categoría Plata 6 Contactos en MINIMO 3 Bandas sin importar Modo
Categoría ORO 6 Contactos en todos los Modos y un MINIMO 3 Bandas
Entre todos los participantes que cumplan las bases , a todos ellos se les obsequiará con un diploma alusivo a la Feria de Almería, gratuito y en formato “pdf para su descarga..en la web habilitada para ello...
6.- Estaciones otorgantes: Serán las pertenecientes a la Sección Local de URE ALMERIA, , otorgando a una misma estación un contacto por banda/día..
8.- No es necesario el intercambio de tarjetas , Si alguien necesita alguna qsl Especial EG7FDA similar al diploma , sera solo vía directa, y deberán remitir sobre auto dirigido con franqueo suficiente para retorno.
9.- La participación en este Diploma comporta la aceptación de las presentes bases, las decisiones del Comité Organizador son inapelables.
QSL via EA7URI.
