Radio Amateurs from Denmark will be active with special call OZ75MAY, 1 - 10 May 2020, to mark liberation of Denmark.
QSL via OZ1ACB, ClubLog OQRS, LOTW, eQSL.
Special award will be available.
Rules:
DX stations (outside continent Europe):
Single mode award (CW / SSB / DIGI)
All QSOs with OZ75MAY must be run in one mode (CW / SSB or DIGI) and with the same call
Gold: 5 points
Silver: 4 points
Bronze: 3 points
OZ75MAY/xx gives 1 point per band whatever / xx. Ie OZ75MAY counts one point per band
OZ75MAY/p gives 2 points per ties regardless of mode.
OZ75MAY/xx counts 1 point per band, only first QSO with OZ75MAY/xx (regardless of different /xx) counts per bands.
Mixed mode award (mix of CW + SSB + DIGI)
All QSOs with OZ75MAY must be run in a minimum of 2 modes (CW, SSB and DIGI counter) and with the same call
Gold: 11 points
Silver: 9 points
Bronze: 7 points
OZ75MAY/xx gives 1 point per band whatever/xx. Ie OZ75MAY counts one point per band and per. mode regardless of /xx
Example: OZ75MAY/xx 1 point on QSO 40M CW, 1 point on 40M SSB, 1 point on 80M DIGI and 1 point on 20M SSTV, a total of 4 points.
OZ75MAY/xx counts 1 point per band and per. mode, only first QSO with OZ75MAY/xx (regardless of different /xx) counts per. band and per. mode.
European stations (continent of Europe):
Single mode award (CW/SSB/DIGI)
All QSOs with OZ75MAY must be run in one mode (CW, SSB or DIGI) and with the same call
Gold: 6 points
Silver: 5 points
Bronze: 4 points
OZ75MAY/xx counts 1 point per band, only first QSO with OZ75MAY/xx (regardless of different/xx) counts per bands.
Gold: 15 points
Silver: 12 points
Bronze: 9 points
OZ75MAY/xx gives 1 point per band whatever/xx. Ie OZ75MAY counts one point per band and per. mode regardless of / xx
For example, OZ75MAY gives 1 point on QSO 40M CW, 1 point on 40M SSB, 1 point on 80M DIGI and 1 point on 20M SSTV, a total of 4 points.
OZ75MAY/xx counts 1 point per band and per. mode, only first QSO with OZ75MAY/xx (regardless of different/xx) counts per. band and per. mode.
If you want to receive the award, check your contacts at
www.clublog.org/logsearch/oz75may and at
clublog.org/logsearch/OZ75MAY/p
to make sure you have the required QSOs is in our log.
You can then apply for the award by sending an e-mail to our award manager OZ4CG (E-mail oz4cg@live.dk). You will then receive an e-mail with your desired award, which is attached at no cost to you.
Rules:
Gold: 5 points
Silver: 4 points
Bronze: 3 points
Gold: 11 points
Silver: 9 points
Bronze: 7 points
Gold: 6 points
Silver: 5 points
Bronze: 4 points
Gold: 15 points
Silver: 12 points
Bronze: 9 points
