2 Special Event Station HS400OZ and OZ400HS will be active on the HF bands in the period
1 September 00:00 UTC until 31 October 23:59 UTC
You may get a diploma by gathering contacts with the two Special Event Stations and also with all other stations in the two countries.
Two-way contacts and SWL reports are valid for the special DENMARK & THAILAND diploma. All contacts with different radio amateurs in the two countries, on different bands and with different modes count 1 (one) point. Each contact with HS400OZ or OZ400HS, on different bands and with different modes counts 10 (ten) points. There must be minimum one (1) contact with both a HS and an OZ station as well as with OZ400HS or HS400OZ Special Event Stations.
Example: Contact with HS400OZ at 20m CW (10) and with OZ1FJB at 20m SSB (1) and with HS1FVL at 20m CW (1) as well as with OZ400HS at 40m CW (10) gives you 22 points.
DENMARK & THAILAND diploma:
- BRONZE = 30 points
- SILVER = 60 points
- GOLD = 120 points
- Special Prize for the Thai and the Danish station that gets the most points
- Special Prize for the radio amateur outside HS and OZ with the highest number of points
Send your request including a list of all your contacts to award manager: OZ4CG@live.dk
QSL cards can be ordered via Clublog OQRS and can be sent via bureau or directly. All logs for both SES calls will be uploaded to Clublog, LoTW and eQSL.
Vy 73 and GL
The OZ-Event team.
OZ1FJB, OZ4CG, OZ1ACB and OZ2I
