Date :
1st Step From 04 to 08 September - Dario Fo
2nd Step. From 18 to 22 September - Enrico Fermi
Bands :
In SSB : always in compliance with the BANDPLAN you can use the bands 10, 15, 20, 40, 80, no WARC.
Cluster : https://www.radioamatoriarpi.it/Home_2.html
To obtain Diplomas the following points are required :
The following are required for the Classic level Diploma: 30 points
For the Bronze level Diploma you need: 60 points
For the Silver level Diploma you need: 120 points
For the Gold level Diploma you need: 200 points
Explanation:
The points just mentioned are required to reach the 4 levels, namely: Classic, Bronze, Silver and Gold and are valid for single-session/step diplomas. To achieve the double-session/step diplomas, the scores must be doubled. To achieve triple-session/step diplomas, scores must be tripled.
No LOG require.
SWL: To apply for the Diploma, one must send the completed log indicating the transmitting and receiving station in Excel or PDF format to QSLM IZ1MLC Vito by email arpi.direttivo@gmail.com
Bands :
Explanation:
No LOG require.
 j.jpg)
