• Rugged smart handset with colour display and integrated GPS
• Multi-language user interface
• Optimised for mobile and base
• 150 W PEP
• Second Generation Digital Voice
• STANAG/MIL-STD-188-110B data waveforms (up to 19k2 bps)
• AES-256 digital COMSEC
• Frequency Hopping
• MIL-STD-188-141B ALE
• Waterproof MIL-STD-810G construction
• IP/USB Connectivity
• Interoperable with Codan Patrol 2110M Manpack
• H-250 Accessories support
• Worldwide Codan service and support
STANDARD CAPABILITIES
• 1.6 to 30 MHz frequency range
• 150 W RF power output
• 1000 channels
• 500 contacts
• Embedded GPS
• 2.4 kHz and wideband filters
• MIL-STD 188-141B ALE
• Robust ARQ data modem
• Codan Selcall
SOFTWARE APPLICATIONS
• TPS-3250 Radio Programming Software
• RC50-C HF Email (for STANAG/ MIL modem)
• Codan Chat HF (for robust ARQ modem)
• Key Management Software
• Key Fill Software
• GPS tracking solution
TRANSCEIVER BASED OPTIONS
•STANAG/MIL data & second generation
Digital voice (2400 bps vocoder) bundle
•AES-256 Encrypted STANAG/ MIL data
& second generation Digital Voice (2400/1200/600
bps vocoder) bundle
•CES-128 voice encryption
•Frequency hopping
•Languages (Dari, Farsi, Pashto, Arabic,
French, Spanish, Russian, Chinese)
•Free tune transmit
•Independent Sideband (ISB)
•Software Developers Kit (SDK)
SPECIFICATIONS
GENERAL ENVIRONMENTAL
Frequency Range TX:1.6 to 30 MHz;
RX: 250 kHz to 30 MHz MIL-STD-810G Shock, vibration, Humidity,
Blowing Dust, Leakage Immersion,
Fungus, Altitude
Channels 1000 Immersion IP67
Programmable Contacts 500 Operating Temperature Range -30 to +60 C
Programmable Networks 20 Relative Humidity 95%
Scan Rate Up to 8 Channels per second DATA WAVEFORMS
RF Input / Output Impedance 50 Ω (N-Type) Proprietary CHIRP/QPSK Up to 6000 bps with compression
Input Voltage 10 V to 35 V DC STANAG 4539 / MIL-STD-188-110A/B 75 to 9600 bps, up to 19,200 bps (ISB)
Supply Current Rx: 650 mA (backlight min, audio muted);
Tx: Two-tone 14 A typical,
average speech 5 A (analogue), 12 A (DV) ECCM: FREQUENCY HOPPING
Channel Filters 500 Hz, 2.4 kHz, 2.75 kHz, 3 kHz
(software defined) Hop Rates 6 /12 /25 hops per second
(user selectable)
Frequency Stability ±0.3 ppm Hop Plans 31 user selectable (direct entry and
programmable via Codan KMS/KFS &
memory stick); 4-digit session PIN
Protection Over-voltage/under-voltage/
over-temperature/
reverse polarity Hop Sequence Pre-defi ned and custom configurable
GPS RFU - external antenna,
Handset - embedded receiver/antenna
(GPS, GLONASS and Beidou) Hop Bandwidth User configurable
Language Support Multiple language user interface
and documentation Synchronisation GPS based
TRANSMITTER DIGITAL VOICE
Power Output 150 W PEP — user programmable Hi, Med, Lo Vocoders STANAG 4591 / MELPe (2400/1200 bps)
TWELP (2400/1200/600 bps)
Duty Cycle 100% voice and data Features Autobaud, automatic vocoder switching, full digital mode
Spurious and Harmonic Suppression >65 dB below PEP ENCRYPTION
Intermodulation >31 dB below PEP MIL/STANAG Data and Digital Voice AES-256 (256 keys, direct entry and
memory stick)
Carrier Suppression >65 dB below PEP Voice encryption CES-128 (97 x 16-digit keys, direct entry and programmable via Codan KMS/KFS
& memory stick, 4-digit session PIN)
Sideband Suppression >65 dB below PEP LINKING
RECEIVER ALE FED-STD-1045
MIL-STD-188-141B
Sensitivity SSB: -125 dBm (0.12 uV) Selcall CCIR 493-4 proprietary and open standard
Selectivity >65 dB at -1 kHz at -1 kHz +4 kHz SCF (USB) INTERFACES
Image Rejections >90 dB ATU Control, General Purpose
Interface, Handset Interface,
DC supply Fully sealed bayonet style MIL connectors
Blocking >95 dB H-250 6-pin MIL supporting audio in/out, PTT, mic
input, audio output, and fused 12 V DC out
Audio Output 4.0 W into 4Ω (external H-250 interface)
0.5 W into 8Ω (handset) GPS Antenna SMB Socket
Noise Reduction DSP proprietary Antenna N-type
Mute Syllabic voice detection — user controlled Ignition Sense Single wire input, part of DC battery cable
MECHANICAL COMPLIANCE
Dimensions (WxHxD) RFU: 220 mm x 66.5 mm x 190 mm
Handset: 67 mm x 210 mm x 72.5 mm Compliance CE, FCC Part 90, AS/NZS 4770, AS/NZS 4355
Weight RFU: 2.82 kg;
Handset: 280 g (no cable)
For more information visit:
https://at-communication.com/en/hf_s..._hf_radio.html
